GL inet Brume 2: Power LED is on but no connection and no reset possible.
Hi there,
I am trying since days to get my Brume 2 back to Life. I don’t know how to proceed. I tried everything what I found in the internet but nothing worked. The Power LED is on (no blinking) but I can’t connect with the device. I also tried to use the fallback IP adress but no connection. So then I tried to reset it but it seems that the reset button is not working anymore. I can press it as long as I want without any change. Can you help me with that topic? I really need the VPN Server and I don’t know what should I try or do to fix that problem.
Br
Martin
Have you tried whether the Brume2 can also enter uboot mode?
If yes, please try to upgrade the uboot version and flash the latest firmware in uboot.
Hi, Thank you for your reply. I tried it dozens of times but still the same behaviour. also during powerup the reset button does not work. I don’t know what to do. The power LED is working but nothing else. :frowning:
Sincerely sorry for the inconvenience caused.
Please contact our customer services team [email protected] by mail, cite this thread, and provide your purchase record (order number).
Thanks!
