OpenVPN not working.
Tue Feb 9 02:06:31 2021 daemon.err openvpn[18594]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Tue Feb 9 02:06:31 2021 daemon.err openvpn[18594]: TLS Error: TLS handshake failed
Tue Feb 9 02:06:31 2021 daemon.notice openvpn[18594]: SIGHUP[soft,tls-error] received, process restarting
Tue Feb 9 02:06:31 2021 daemon.warn openvpn[18594]: WARNING: --keysize is DEPRECATED and will be removed in OpenVPN 2.6
Tue Feb 9 02:06:31 2021 daemon.notice openvpn[18594]: OpenVPN 2.5_git mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Tue Feb 9 02:06:31 2021 daemon.notice openvpn[18594]: library versions: OpenSSL 1.1.1d 10 Sep 2019, LZO 2.10
Tue Feb 9 02:06:31 2021 daemon.notice openvpn[18594]: Restart pause, 5 second(s)
Tue Feb 9 02:06:36 2021 daemon.warn openvpn[18594]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Tue Feb 9 02:06:36 2021 daemon.warn openvpn[18594]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Tue Feb 9 02:10:53 2021 daemon.notice openvpn[24144]: Socket Buffers: R=[163840->327680] S=[163840->327680]
Tue Feb 9 02:10:53 2021 daemon.notice openvpn[24144]: UDP link local: (not bound)
Tue Feb 9 02:10:53 2021 daemon.notice openvpn[24144]: UDP link remote: [AF_INET]104.194.220.24:1195
Tue Feb 9 02:11:42 2021 daemon.err openvpn[23431]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Tue Feb 9 02:11:42 2021 daemon.err openvpn[23431]: TLS Error: TLS handshake failed
Tue Feb 9 02:11:42 2021 daemon.notice openvpn[23431]: SIGHUP[soft,tls-error] received, process restarting
Tue Feb 9 02:11:42 2021 daemon.warn openvpn[23431]: WARNING: --keysize is DEPRECATED and will be removed in OpenVPN 2.6
Tue Feb 9 02:11:42 2021 daemon.notice openvpn[23431]: OpenVPN 2.5_git mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
