Hello everyone,
I’m trying to understand some stability and behavior issues I’m observing on the GL.iNet GL-MT6000 running OpenWrt 21.02 snapshot (v4.9), especially related to LAN DNS behavior and SQM in a dual-WAN environment.
I would like to know if others have experienced similar behavior or if this is expected design limitation.
1. LAN DNS Stability Issue
Problem observed:
Devices connected to LAN (especially iPhones) occasionally show:
Connected to WiFi but “No Internet”
DNS resolution failures or inconsistent responses
Browsing works intermittently even when ping to public IPs is fine
My setup:
Router: GL.iNet GL-MT6000 (OpenWrt 21.02 snapshot)
LAN: 10.1.1.0/24 (br-lan)
DHCP handled by dnsmasq
AdGuard Home installed (used for DNS filtering on port 3053, sometimes disabled for testing)
Dual WAN:
WAN (eth1 → ISP router)
WWAN (WiFi repeater / apclix0)
What I noticed:
The issue seems related to DNS routing inside LAN, such as:
dnsmasq sometimes forwarding DNS to:
AdGuard (127.0.0.1#3053)
ISP DNS servers
or fallback resolvers
DHCP DNS options changing behavior depending on configuration state
Missing or inconsistent /tmp/resolv.conf.auto
Clients receiving different DNS behavior depending on routing state
Question (LAN DNS):
Has anyone experienced:
LAN devices connected but showing “No Internet”?
DNS instability when using AdGuard with dnsmasq?
Problems after changing DHCP DNS settings?
Recommended stable LAN DNS architecture for MT6000?
2. SQM / QoS Behavior in Dual WAN Setup
Observation:
When using SQM (cake/fq_codel):
It seems to mainly control WAN interface traffic only
LAN-originated traffic or secondary interface flows may not always be shaped consistently
In dual-WAN setup, behavior becomes less predictable
Some traffic appears to bypass expected queue discipline depending on routing path
My setup:
Dual WAN:
WAN (eth1)
WWAN (apclix0 WiFi repeater)
LAN bridge: br-lan (10.1.1.1)
Policy routing not heavily customized
Question (SQM):
Is this expected behavior in OpenWrt SQM?
Specifically:
Does SQM only shape egress WAN traffic by design?
Can SQM be applied effectively to LAN-side flows or bridge interfaces?
Any recommended configuration for dual-WAN + SQM stability?
Any known limitations on MT7986 / GL-MT6000 platform?
Summary
It looks like I may be dealing with two related areas:
LAN DNS inconsistency (likely dnsmasq / AdGuard interaction)
SQM behavior being WAN-centric by design
I would appreciate any clarification or best practice recommendations.
Thanks in advance ![]()
