GL.iNet GL-XE3000 - eSIM profile download stops at 90%
Just tried to download eSim profile and it stops at 90%. I have physical eiotclub eSim card. The firmware of the router is up to date. I have photo of the log if needed.
Err message: Init auth fail. | exit status 35
And there is some ac code.
I have contacted Eliot club and they said everything looks fine on their side.
I found similar issue related to a different model of router so not helpful in my case.
Thank you in advance for any kind of help.
Edit:
Sorted
The only thing that helped was reset, adding profile then firmware update to the last stable version.
