GL-iNet router used to sync OneDrive (rsync) to SD card - would that work?
Hello Colleagues,
I must say i just recently discovered this product(s) but seems like a something that would cover my needs.
On top of the vpn, ad blocking/pi-hole, I would like to have a OneDrive backup to SD. I learned about the rsync, which seems as a good solution, but i have two questions:
  • will any of the routers work well in this scenario, i.e., sync/download OneDrive to SD card?
  • does it work?:wink:
thank you!
rsync won't help here, you might need to have a look into rclone instead.
Will it work? Maybe. It depends on the router and the power needed. Worth a try.
good start from my end - yes, rclone is what i had on my mind before making this faux pas.
thank you!
rclone (specially with onedrive) needs CPU and RAM (a lot). rclone will run but horribly slow.
I use OneDrive with rclone on my PC and I have dropped it because it was very slow. I don't know how could it perform on a router, but it should work.
thank you all!
performance was my concern - and it seems to be a justified one!
