I'm just wondering if one exists for the Slate 7? I don't see any with a quick search on Amazon.
If you have torn off the original plastic wrap, just buy "cutting sheet" to tailor made the screen protector yourself, it's cheap and easy.
Oh? Is there already a pre-installed screen protector?
There is not pre-installed screen protector, original just a plastic film in screen.
You can buy some cheap screen plastic protector and then cut it yourself according to the size of the screen.
Any pictures to show what it looks like?
