GL-inet, we need a proper cellular router
Hi @gladly The Puli series will retain at least 2 Ethernet ports, whereas the Mudi series can only possess 1 Ethernet port due to size constraints.
We have plans to upgrade the Puli AX/XE3000, with options such as X72 or X82 under consideration.
Furthermore, we are considering an upgraded version of the Puli/XE300, though the chip solution has not yet been finalized. Regarding VPN speed, we would like to know your expected speed (it may range between the speeds of the XE300 and XE3000). Moreover, is OpenWRT a must-have for you or would you consider an Android platform?
For me and I think many people it must be based on OpenWRT.
VPN speed should should be minimum 100 but of course more is better.
