Setup:
Server: GL.iNet Router Beryl AX (Home ISP -> GL.iNet Server). LAN: 192.168.8.1.
Client: GL.iNet Travel Router Berly AX (connected to 172.x series Wi-Fi). LAN: 192.168.10.1.
VPN Protocol: WireGuard.
Status: Connects initially, I can browse and verify my Home IP, but then randomly drops and gets stuck in "Connecting" with REKEY-GIVEUP logs.
Firmware: 4.8.5 on both
What I've already tried:
1. Profiles: Verified I am using a unique Client Profile/Key for the router (different from my phone).
2. Mobile Test/laptop test: My phone connects to the same home server perfectly on the same network using its own profile.
3. MTU: Changed from 1420 to 1280 (and even lower).
4. PersistentKeepalive: Tried both 25 and 15.
5. DNS: Tried Manual (8.8.8.8), Automatic, and Home Server IP (192.168.8.1 ).
6. Kill Switch: "Block Non-VPN Traffic" is enabled (verified it works; internet dies when VPN drops).
7. Subnets: No conflict (Home 192.168.8.x, Client 192.168.10.x, WAN 172.x.x.x).
8. Hardware: AdGuard Home is OFF.
9. Port Forwarding: Correctly set up at home (UDP).
The Issue:
The connection is unstable. It will work for a few minutes, then fail. When it fails, the logs show REKEY-GIVEUP. Even after a reboot, it might connect for a moment and then drop again.
