GL-KVM app with two KVMs
When I attempt to connect to one of the two GL-iNet comet KVMs using the GLKVM application, I am able to connect without issue. Then, when I attempt to connect to a second KVM from within GLKVM application, the first application window terminates / shuts down and the second KVM app window opens up.
It seems odd that only one KVM app window is allowed at a time. So I am assuming there is some configuration for allowing multiple KVM application windows connected to multiple KVMs.
What am I missing?
I am running what I think is the latest version of GLKVM application for MacBook / OSX. I am using version 1.2.0 release version.
Jeff
The current version of the client does not currently support simultaneous access to multiple devices. We will be gradually updating this feature. If you need to access multiple devices at the same time, you can try using KVMCloud at the following link: https://www.glkvm.com.
