GL-M2 dev board - power through USB C port?
Folks,
A couple of questions on the GL-M2 development board:
  1. Is it possible to power the board and modem through the USB C port while tethering to a router?
  2. Is it possible to power the board and modem through the USB C port using a USB C hub that is connected to an external power source? IF so, could you then use a USB C hub with an RJ45 jack and connect an ethernet cable from the USB C hub to a router?
Just thinking outside the box on ideas for the development board.
Eric
