Hey there
i´m planning to use stock openwrt, but i want to notified when the battery is low, in the glinet firmware there is a app called gl-mifi-mcu, so i´m looking to get the voltage readings by SPI, or i2c, is there a way i can get voltage readings using my own program?
i´m a little bit sad you cannot give informations about that, anything is build for DIY Use, but when you want use those diy features (i´m assuming the MCU is connected to 2 GPIO pins of the domino core) you cannot get any documentation about that.
or how about just make the gl-mifi-mcu package open source?
