Just bought the GL-Mifi and been trying it out for my purpose which I tried to describe in the subject. In the image there’s a little more info on what I’m trying to do. I have so got the following working:
LTE-connection
OpenVPN-tunnel to my server
Private Wifi with login
What I need help with is how to set the whole flow up, especially the lower part, i.e. the Guest Wifi part where I want my guests to connect to an open SSID, get an 192.168.1.x adress coming from the DHCP server which is connected to the Wifi through the OpenVPN connection.
edit /etc/config/firewall or do it in luci, add rule for guest to the end
config rule 'guest'
option src 'lan_guest'
option dest 'VPN_client' #If you don't want guest to use vpn, here should be " option dest 'wan' "
option proto 'udp tcp'
option target 'ACCEPT'
5. Finally reboot your device. If you do this in Luci, there changes should be applied automatically, no need reboot.
Thanks for a quick reply but unfortunately I do need the DHCP Relay coming from the server. That’s the most important part of the setup that a guest connects to the “Guest” SSID, the Mifi setups a tunnel to the server with a DHCP Relay to 192.168.0.1, the server then handles the DHCP and gives the user an adress in the range 172.16.0.x - the attached image last time were wrong.
I have attached four images coming from the admin tool of a competitor of yours called Teltonika RUT950. The functionality is good but I want to use your product instead since it’s better, looks better and has a battery. Can you look at the images and from that figure out how to duplicate that on a GL-Mifi. That would be fantastic. The images shows the WAN setting, the LAN setting and the OpenVPN setting. Needed is to disable NAT and to use the DHCP Relay.
