I’m running into this issue with the EC-25A Quectel module. If the cellular data is paused (from the carrier side) and resumed, the modem will not come back up. I’m trying to reset the modem but sometimes it crashes the mifi, other times it works, and other times it doesn’t work. Is there an AT command that can be used to “restart” the modem?
Just to make sure I get this right… When you click reset, it runs " AT+QPOWD"?
