Hi, I’m using several Gl-MiFis as OpenVPN clients TAP. I use these routers in remote location, connected to other system for service purpose. Everything seems to work correctly, but I’m not able to access to the web configuration UI of the Gl-Mifis, from OpenVPN server side.
I use a FreshTomato router as OpenVPN TAP server.
Some examples:
FreshTomato OpenVPN server router:
- local LAN: 192.168.223.100 - 192.168.223.253 DHCP
- OpenVPN server client address pool: 192.168.223.1 - 192.168.223.99 no DHCP
Gl-MiFi 1
- local IP: 192.168.101.1
- local LAN: 192.168.101.10 - 192.168.101.19 DHCP
Gl-MiFi 2
- local IP: 192.168.102.1
- local LAN: 192.168.102.10 - 192.168.102.19 DHCP
When Gl-MiFi 1 connects to OpenVPN server, gets the OpenVPN IP for example 192.168.223.1, and also the Gl-MiFi clients get the IPs from the server. I can ping and navigate every clients without problem, but if I try to ping or open the web UI at the following addresses: 192.168.223.1 or 192.168.101.1, I cannot connect nor have an answer.
I need to configure Gl-MiFis from remote (server side). Is this possible?
Note that I cannot use any ddns service or direct remote access, because I use Gl-MiFis connected to Internet via 3G modem. 3G network is under NAT, without direct connection.
Thank you
