I was not sure how to use the “dmesg”… started the ssh and run “dmesg” and this is what returned…
[ 0.000000] Linux version 4.4.92 (kyson@gl-inet) (gcc version 5.4.0 (LEDE GCC 5.4.0 r3560-79f57e422d) ) #0 Tue Oct 17 17:46:20 2017
[ 0.000000] MyLoader: sysp=bd78c578, boardp=d6d8f7ae, parts=9079e6dc
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] No valid device tree found, continuing without
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat 804444d0, node_mem_map 8100000 0
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 16256
[ 0.000000] Kernel command line: board=GL-MIFI mtdparts=spi0.0:256k(u-boot)r o,64k(u-boot-env)ro,16000k(firmware),64k(art)ro console=ttyATH0,115200 rootfstyp e=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 59840K/65536K available (3160K kernel code, 188K rwdata, 788K rodata, 336K init, 205K bss, 5696K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.00 0MHz
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_i dle_ns: 9556302233 ns
[ 0.000013] sched_clock: 32 bits at 200MHz, resolution 5ns, wraps every 10737 418237ns
[ 0.007555] Calibrating delay loop… 265.42 BogoMIPS (lpj=1327104)
[ 0.088738] pid_max: default: 32768 minimum: 301
[ 0.093346] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.099494] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.110130] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns
[ 0.118183] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.126007] NET: Registered protocol family 16
[ 0.130933] MIPS: machine is GL-MIFI
[ 0.620402] clocksource: Switched to clocksource MIPS
[ 0.625865] NET: Registered protocol family 2
[ 0.630019] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.635401] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.641450] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.647615] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.653107] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.659424] NET: Registered protocol family 1
[ 0.663318] PCI: CLS 0 bytes, default 32
[ 0.669735] Crashlog allocated RAM at address 0x3f00000
[ 0.695404] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.699625] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORIT Y) (c) 2001-2006 Red Hat, Inc.
[ 0.712995] io scheduler noop registered
[ 0.715368] io scheduler deadline registered (default)
[ 0.720704] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.730615] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11, base_baud = 15 62500) is a AR933X UART
[ 0.738422] console [ttyATH0] enabled
[ 0.745287] bootconsole [early0] disabled
[ 0.759928] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.763978] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.768600] 4 cmdlinepart partitions found on MTD device spi0.0
[ 0.774488] Creating 4 MTD partitions on “spi0.0”:
[ 0.779253] 0x000000000000-0x000000040000 : “u-boot”
[ 0.787337] 0x000000040000-0x000000050000 : “u-boot-env”
[ 0.793611] 0x000000050000-0x000000ff0000 : “firmware”
[ 0.815291] 2 uimage-fw partitions found on MTD device firmware
[ 0.819771] 0x000000050000-0x0000001b0000 : “kernel”
[ 0.826788] 0x0000001b0000-0x000000ff0000 : “rootfs”
[ 0.832743] mtd: device 4 (rootfs) set to be root filesystem
[ 0.836989] 1 squashfs-split partitions found on MTD device rootfs
[ 0.843208] 0x0000009b0000-0x000000ff0000 : “rootfs_data”
[ 0.851020] 0x000000ff0000-0x000001000000 : “art”
[ 0.874803] libphy: ag71xx_mdio: probed
[ 1.462115] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd0 41, driver=Generic PHY]
[ 1.470856] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[ 2.061885] ag71xx-mdio.1: Found an AR7240/AR9330 built-in switch
[ 2.093963] eth1: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[ 2.102091] NET: Registered protocol family 10
[ 2.111038] NET: Registered protocol family 17
[ 2.114137] bridge: automatic filtering via arp/ip/ip6tables has been depreca ted. Update your scripts to load br_netfilter if you need this.
[ 2.126866] 8021q: 802.1Q VLAN Support v1.8
[ 2.133311] hctosys: unable to open rtc device (rtc0)
[ 2.142948] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[ 2.151242] Freeing unused kernel memory: 336K
[ 3.591300] init: Console is alive
[ 3.593551] init: - watchdog -
[ 6.464535] kmodloader: loading kernel modules from /etc/modules-boot.d/
[ 6.653905] usbcore: registered new interface driver usbfs
[ 6.658068] usbcore: registered new interface driver hub
[ 6.663475] usbcore: registered new device driver usb
[ 6.677340] exFAT: Version 1.2.9
[ 6.739707] SCSI subsystem initialized
[ 6.751585] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 6.759456] ehci-platform: EHCI generic platform driver
[ 6.763454] ehci-platform ehci-platform: EHCI Host Controller
[ 6.769016] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 6.779028] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 6.800454] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 6.806588] hub 1-0:1.0: USB hub found
[ 6.809444] hub 1-0:1.0: 1 port detected
[ 6.818083] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 6.825366] ohci-platform: OHCI generic platform driver
[ 6.833294] uhci_hcd: USB Universal Host Controller Interface driver
[ 6.845144] usbcore: registered new interface driver usb-storage
[ 6.850876] kmodloader: done loading kernel modules from /etc/modules-boot.d/ *
[ 6.860650] init: - preinit -
[ 7.280559] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 7.543936] random: procd: uninitialized urandom read (4 bytes read, 13 bits of entropy available)
[ 7.552186] hub 1-1:1.0: USB hub found
[ 7.560681] hub 1-1:1.0: 4 ports detected
[ 7.809591] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.980440] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
[ 8.096708] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 8.102624] scsi host0: usb-storage 1-1.1:1.0
[ 9.102505] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 0233 PQ : 0 ANSI: 0
[ 9.116634] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 11.124337] jffs2: notice: (430) jffs2_build_xattr_subsystem: complete buildi ng xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 11.140349] mount_root: switching to jffs2 overlay
[ 11.157943] urandom-seed: Seeding with /etc/urandom.seed
[ 11.434145] procd: - early -
[ 11.435712] procd: - watchdog -
[ 12.310745] procd: - watchdog -
[ 12.312833] procd: - ubus -
[ 12.791457] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
[ 12.799622] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
[ 12.808125] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
[ 12.817494] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
[ 12.825949] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
[ 12.835104] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
[ 12.844323] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
[ 12.853295] procd: - init -
[ 14.386694] random: jshn: uninitialized urandom read (4 bytes read, 27 bits o f entropy available)
[ 14.566547] kmodloader: loading kernel modules from /etc/modules.d/*
[ 14.719677] random: ubusd: uninitialized urandom read (4 bytes read, 27 bits of entropy available)
[ 15.683885] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 15.762779] Initializing XFRM netlink socket
[ 15.774513] NET: Registered protocol family 15
[ 15.804086] tun: Universal TUN/TAP device driver, 1.6
[ 15.807690] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 16.042960] l2tp_core: L2TP core driver, V2.0
[ 16.068462] l2tp_netlink: L2TP netlink interface
[ 16.115027] gre: GRE over IPv4 demultiplexor driver
[ 16.122580] ip_gre: GRE over IPv4 tunneling driver
[ 16.178138] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 16.228204] Netfilter messages via NETLINK v0.30.
[ 16.243659] ip_set: protocol 6
[ 16.366692] i2c /dev entries driver
[ 16.406080] Linux video capture interface: v2.00
[ 16.510909] u32 classifier
[ 16.512160] input device check on
[ 16.515805] Actions configured
[ 16.534539] Mirror/redirect action on
[ 16.598099] nf_conntrack version 0.5.0 (940 buckets, 3760 max)
[ 16.701538] fuse init (API version 7.23)
[ 16.832199] usbcore: registered new interface driver cdc_acm
[ 16.836410] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
[ 16.883937] usbcore: registered new interface driver cdc_wdm
[ 16.906559] Loading modules backported from Linux version wt-2017-01-31-0-ge8 82dff19e7f
[ 16.913219] Backport generated by backports.git backports-20160324-13-g24da7d 3c
[ 16.984446] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 17.004263] usbcore: registered new interface driver ipheth
[ 17.233384] usbcore: registered new interface driver usbserial
[ 17.237905] usbcore: registered new interface driver usbserial_generic
[ 17.244488] usbserial: USB Serial support registered for generic
[ 17.424607] xt_time: kernel timezone is -0000
[ 17.433130] usbcore: registered new interface driver cdc_ether
[ 17.458519] usbcore: registered new interface driver cdc_ncm
[ 17.593116] usbcore: registered new interface driver cp210x
[ 17.597388] usbserial: USB Serial support registered for cp210x
[ 17.621033] gspca_main: v2.14.0 registered
[ 17.644054] usbcore: registered new interface driver sonixb
[ 17.660022] usbcore: registered new interface driver sonixj
[ 17.678854] usbcore: registered new interface driver gspca_zc3xx
[ 17.702987] usbcore: registered new interface driver huawei_cdc_ncm
[ 17.925017] PPP generic driver version 2.4.2
[ 17.952149] PPP MPPE Compression module registered
[ 17.958975] NET: Registered protocol family 24
[ 17.972377] PPTP driver version 0.8.5
[ 17.983282] usbcore: registered new interface driver qmi_wwan
[ 18.016798] usbcore: registered new interface driver rndis_host
[ 18.036153] usbcore: registered new interface driver sierra
[ 18.040515] usbserial: USB Serial support registered for Sierra USB modem
[ 18.062872] usbcore: registered new interface driver sierra_net
[ 18.118399] usbcore: registered new interface driver uvcvideo
[ 18.122775] USB Video Class driver (1.1.1)
[ 18.286665] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 18.299899] usbcore: registered new interface driver option
[ 18.304258] usbserial: USB Serial support registered for GSM modem (1-port)
[ 18.390230] ath: EEPROM regdomain: 0x0
[ 18.390263] ath: EEPROM indicates default country code should be used
[ 18.390277] ath: doing EEPROM country->regdmn map search
[ 18.390305] ath: country maps to regdmn code: 0x3a
[ 18.390321] ath: Country alpha2 being used: US
[ 18.390335] ath: Regpair used: 0x3a
[ 18.402531] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
[ 18.410731] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 18.460755] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 39.323304] device eth1 entered promiscuous mode
[ 39.340666] br-lan: port 1(eth1) entered forwarding state
[ 39.344668] br-lan: port 1(eth1) entered forwarding state
[ 39.445191] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 40.270590] br-lan: port 1(eth1) entered disabled state
[ 44.638400] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 44.746924] device wlan0 entered promiscuous mode
[ 47.535677] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 47.540920] br-lan: port 2(wlan0) entered forwarding state
[ 47.546117] br-lan: port 2(wlan0) entered forwarding state
[ 49.540496] br-lan: port 2(wlan0) entered forwarding state
[ 58.330493] random: nonblocking pool is initialized
[ 789.411968] eth0: link up (100Mbps/Full duplex)
[ 789.415102] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
