On the GL-MiFi, the mPCIe connector is USB only (or does it have PCIe signals as well) ?
Most WWAN cards use USB, so can I use a WWAN card and the external USB at the same time ?
it is only USB.
It only has one USB-A port. You can use the MicroSD slot for storage.
