Hello!
4 years ago I started a project to have access to an industrial PC from anywhere. At that time I used a Mikrotik with a USB Router.
Taking back the project I searched some information about new technology and found this router that have everytinng in one piece. I have bought a new 4g Router GL-MiFi.
Now i started up with the configuration but i do not understand somethings.
Let me explain the configuration that I want.
So, how i start?
-The DDNS form no-ip its configured (Downloaded the DNS Script and NO-IP script)
but how i config the interface? already tested but the configuration assings the dns to the “industrual PC” ip. And I want assing to the 4g interface ip.
-Where i need to setup the outside connections form protocol ssh and ftp redirects to the industrial PC?
Thank you!
Edit: Alredy founded the solution. Reset the modem and start config all again. And was simple
- Set up 3G info
- Set up DDNS soft and no.ip script.
- Set up firewall rule that Modem conections go to “Industrial pc”
