For some reason my new Gl MiFi stopped being able to join to an wireless AP.
Basically I do a scan, and get it to connect to one of my many AP’s here.
It will save fine, but it will never connect to it (tested with open and closed AP’s).
The signal indicator will also stay on 0%
I’ve reset the GL MiFi several times to it’s original settings, but no luck.
This used to work perfect!
If you want to try to salvage this, try one or both of the following:
Advanced=>Luci=>Networking=>Wifi=> delete the STAtion(s) (NOT THE AP it's perspective, your STAtion is connecting to an(other) AP, not the one the MIFI is broadcasting)
Reset the device holding the reset button in for at least 10 seconds. This will wipe all config.
A better solution, which will also wipe your config, is to upgrade to the just released 2.22. It has some much improved Station Management functions which I have just been testing.
I know how to connect to an AP with the MiFI, and this used to work perfect.
I have also reset the MiFI several times, but still no luck.
I’ve also just flashed the new 2.22, but again still no luck. The signal indicator (under Wireless Overview in Luci) stays on 0%, and no coneection is being made with the AP.
Hmmm it must have been some kind of ID 10 T error (read IDIOT), but it’s working again!
Not sure if the way I connected (after many resets) made a difference.
I now connected by using the “GL.Inet > WAN settings > Repeater” option.
Before this I always used the “Advanced settings > Network > Wifi” option to make a connection.
