GL-MT1300 - 500 - Internal Server Error
Not able to login into advance settings. 500 - Internal Server Error. I already tried using terminal to install luci successful but the error is not resolved. Not sure what a solution could be.
This is generally because the web server crashes.
Suggesting do a reboot. If not fixed do a firmware reset.
I’m looking for a less destructive solution… Also no possibility to do a backup. A reboot doesn’t do the trick…
