I have tried both routers, the procedure is as below,
connect TCL phone to the usb port
allow data access from the phone
turn on usb tethering manually.
Both routers could not detect usb tethering.
The same TCL works on gl-mt300n-v2.
Is it the usb 3.0 port issue?
alzhao
June 30, 2021, 6:25am
#2
Can you give the log on MT1300 and MT300N-V2, when you get your TCL connected to the router.
Use the following to get the log
ls /dev/
ifconfig -a
logread
Thanks for the help! I tried to collect log today but noticed a update available to 3.2.01. After upgrade, mt1300 can do usb tethering with the TCL now.
