Could you guys please fix the WIFI bug on GL-MT1300? I’ve bought one off Amazon, and the WIFI keeps disconnecting no matter what my settings are. This issue is well known within the Beryl’s community. My current workaround’s disabling WIFI and using another router as AP.
I have spent so much time trying to deal with the connection dropping issues and I don’t see any updates that solve it. I have worked with support showing the consistent internal logs showing the problem and read others having similar issues.
Looks like there will not be any resolution and I’m left with finding a new product.
Suggestions on other mobile routers that I should consider to replace the Beryl?
Same issues, maybe worse now. Connection drops, if I connect to my source mobile router no problem, but when through Beryl which is Ethernet cable connected to source it drops every few minutes.
Same here, random disconnects from a normally reliable network… here is my kluge workaround til’ I find another router. Too bad, I like the Beryl otherwise. Connecting to network (captive) via PB wifi adapter, then sharing thru Ethernet to Beryl WAN port… works 24/7. Regards, G7
