Hello All, I installed Collectd-mod-iwinfo, but nothing reports back in influxdb. I checked the Luci page, at the bottom, I see stations but no information available. My other gl.inet router has this feature. Can someone help me enable this for the Beryl?
Associated Stations
Network
MAC-Address
Host
Signal / Noise
RX Rate / TX Rate No information available
So Gl.inet, can you guys fix this? This is terrible if true. Otherwise, I’m going to return it and advocate to many that this router doesn’t follow the gl.inet standard.
For the mediatek based routers (Mango and Beryl). Gl uses the proprietary MT WiFi drivers for stability/reliability/performance. These are not compatible with LUCI.
I suspect the other gl router you have is atheros based which is Luci compatible hence you can do what you want to do and see what you want to see.
You can try native Open WRT on the MT1300 which would use open source drivers (looks like there’s a snapshot available) and see if that does what you want.
