i would not say solved, the router continues dropping connection when an excessive number of DNS queries are made: I do some testing with BIND RPZ on raspberry pi and it seems i hit the router’s limitation. hopefully, it can be corrected programmatically, but I have not figured out how to do so.
FYI: the rate it’s happening is dozens of queries per second - unlikely can be achieved by a healthy system. so I suspect @alistair23 might have something suspicious going on on his system (a bot infection?)
with this rate of testing no dropped connections, but if i 2-3x increase it I will experience the same drops
I’m having the same problem with the Wifi. It keeps dropping out. I’m wondering if it’s related to the FRAG Wifi attacks patched in the latest firmware which seems to be hung up for this router specifically. It was fine on 3.201 up until the last week or so. I’ve tried upgrading to 3.203 Beta but the wifi wasn’t working with the build so I had to downgrade it back to 3.201. Still have the same problem. Hugely annoying at the moment since it’s dropping and locking up my zoom calls and tv streams. If anyone has any ideas, I’m getting pretty annoyed and might swap for another device until the next firmware lands.
It might not be the same problem here, but I found that with the wi-fi was frequently dropping out on both 2 GHz and 5 GHz. The issue turned out to be automatic scanning. Once I unchecked ‘Auto scan and re-connect’ in the repeater options, the problem went away.
The behaviour only appeared after I added my phone’s hotspot to the list of known networks.
Have the same issue on my devices when connected to WiFi on MT1300. Running latest firmware.
I also have a LOT of DHCP requests that keep showing up in the logs, just like @alistair23
They are from Windows 10 computers. My only workaround was to set static IP on both my windows machines. I do not have this issue on any other router so there is some odd interaction between MT1300 and Windows 10. Not sure this will address the WiFi disconnect issue, but will re-post if reducing the DHCP requests has any effect.
Either way, GL should look into why Windows 10 causes so many DHCP requests. It looks like every 45 seconds the Windows 10 machine calls for new DHCP:
Wed Oct 27 12:31:29 2021 daemon.info dnsmasq-dhcp[2880]: DHCPACK(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d ASUS
Wed Oct 27 12:32:16 2021 daemon.info dnsmasq-dhcp[2880]: DHCPREQUEST(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
Wed Oct 27 12:32:16 2021 daemon.info dnsmasq-dhcp[2880]: DHCPACK(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d ASUS
Wed Oct 27 12:32:59 2021 daemon.info dnsmasq-dhcp[2880]: DHCPREQUEST(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
Wed Oct 27 12:32:59 2021 daemon.info dnsmasq-dhcp[2880]: DHCPACK(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d ASUS
Wed Oct 27 12:33:45 2021 daemon.info dnsmasq-dhcp[2880]: DHCPREQUEST(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
Wed Oct 27 12:33:45 2021 daemon.info dnsmasq-dhcp[2880]: DHCPACK(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d ASUS
Wed Oct 27 12:34:30 2021 daemon.info dnsmasq-dhcp[2880]: DHCPREQUEST(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
Wed Oct 27 12:34:30 2021 daemon.info dnsmasq-dhcp[2880]: DHCPACK(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d ASUS
Wed Oct 27 12:35:15 2021 daemon.info dnsmasq-dhcp[2880]: DHCPREQUEST(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
Wed Oct 27 12:35:15 2021 daemon.info dnsmasq-dhcp[2880]: DHCPACK(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d ASUS
Wed Oct 27 12:36:00 2021 daemon.info dnsmasq-dhcp[2880]: DHCPREQUEST(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
Wed Oct 27 12:36:00 2021 daemon.info dnsmasq-dhcp[2880]: DHCPACK(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d ASUS
Wed Oct 27 12:36:46 2021 daemon.info dnsmasq-dhcp[2880]: DHCPREQUEST(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
Wed Oct 27 12:36:46 2021 daemon.info dnsmasq-dhcp[2880]: DHCPACK(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d ASUS
Wed Oct 27 12:37:32 2021 daemon.info dnsmasq-dhcp[2880]: DHCPREQUEST(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
Wed Oct 27 12:37:32 2021 daemon.info dnsmasq-dhcp[2880]: DHCPACK(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d ASUS
Wed Oct 27 12:38:15 2021 daemon.info dnsmasq-dhcp[2880]: DHCPRELEASE(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
Wed Oct 27 12:38:19 2021 daemon.info dnsmasq-dhcp[2880]: DHCPDISCOVER(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
Wed Oct 27 12:38:19 2021 daemon.info dnsmasq-dhcp[2880]: DHCPOFFER(br-lan) 192.168.8.181 98:2c:bc:d4:b8:1d
I’m having this exact issue as well. DHCP log floods from my windows laptop, and even when I put it to static IP I’m getting wifi drops over and over. Firmware version is 3.203 and keep seeing this in the kernel log, xx:xx:xx:xx:xx:xx is my laptop mac
It all started when I connected an apple TV hardwired into the router and now I unplugged it and it is stopped disconnecting me. Not sure if there was an IP conflict or something. But it’s no longer dropping my windows laptop and the dhcp log flood stopped.
