I’ll start by saying I am a complete novice when it comes to this sort of thing so my apologies if I’m not making sense!
We own a farm and would like to setup two Helium Miners to create coverage for IoT devices, I recently bought a new Hotspot and have set this up in our out building about 400 to 500 meters away, we only have one internet connection to our property and cables have already been run to our outbuilding (has been for years) and our devices plug into a switch in that building.
I assumed it would be a plug and play situation but the outbuilding gets the internet from our switch in the main house and this causes an issue as both hotspots are on the same connection and are both using port 44158 and causing the hotspots to become ‘relayed’ after a little research (limited I might add) and speaking to other I was advised to get a GL-MT1300.
I have made a diagram of the setup and for ease of use (assuming it’s a plug and play situation) I have left the outbuilding switch out of it as I assume the hotspot can be plugged in after.
Any help would be great, am I even able to have both devices with the ports opened? I assumed with the VPN and VPN policy active having port forwarding to both devices would be possible?
Many Thanks,
LCH
