I have a GL-MT1300 that I’ve updated to the 3.211 firmware. This upgrade allows me to enter a username and password for a WiFi network, which seems like it would be EAP support.
Whenever I try to connect to it with my Beryl, I get the error “wpa_supplicant error” and it doesn’t connect. Is there something that I’m doing wrong?
Here are the settings that the connection guide for provided by the network provider gave me:
EAP Method: PEAP
Phase 2 authentication: None
CA certificate: Do not validate
Anonymous identity: leave blank
Network SSID: --------
Security: 802.1x EAP (or WPA2 Enterprise, or WPA2 EAP)
eric
June 13, 2022, 9:19pm
2
You may want to check this post on EAP support on the MT1300
Unfortunately, like MT300N-V2, Beryl MT1300 does not work with EAP
mbg
June 14, 2022, 5:37am
3
Is there a list of GL.inet routers not working with EAP, or is there a list that officially does?
alzhao
June 14, 2022, 8:02am
4
Pls refer to Extensible Authentication Protocol - GL.iNet Docs
Supported models: GL-AR300M Series, GL-USB150, GL-AR750, GL-AR750S, GL-B1300, GL-S1300, GL-AP1300, GL-E750, GL-X750, GL-MiFi, GL-XE300, GL-AX1800, GL-B2200, GL-X300B, GL-X1200
Not supported models: GL-MT300N-V2, microuter-N300, GL-MT1300, GL-MV1000W, GL-MV1000, GL-SF1200, GL-SFT1200
