GL-MT2500 - GNU Parted to correct GPT errors
[ 1.080617] NET: Registered protocol family 17
[ 1.085127] Bridge firewalling registered
[ 1.089258] 8021q: 802.1Q VLAN Support v1.8
[ 1.168637] mmc0: new high speed MMC card at address 0001
[ 1.175038] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 1.180309] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 1.186945] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 1.192940] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (249:0)
[ 1.201949] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 1.209353] GPT:1 != 15269887
[ 1.212306] GPT:Alternate GPT header not at the end of the disk.
[ 1.218305] GPT:1 != 15269887
[ 1.221263] GPT: Use GNU Parted to correct GPT errors.
[ 1.226415] mmcblk0: p1 p2 p3 p4 p5 p6
[ 2.121644] block2mtd: mtd0: [log] erase_size = 64KiB [65536]
[ 2.127546] hctosys: unable to open rtc device (rtc0)
[ 2.134740] VFS: Mounted root (squashfs filesystem) readonly on device 179:6.
[ 2.142079] Freeing unused kernel memory: 448K
[ 2.153049] Run /sbin/init as init process
GPT partition table is corrupted?
The router is ok, but shows this in Kernel Log after boot.
This is normal?
GL-MT2500
Firmware: 4.7.4
my MT2500 kernel also has the same log.
This part is from the MTK source code. The R&D guys have consulted with MTK.
It does not affect the router start-up and the firmware operation, it can be ignored.
Update:
All mt79xx+emmc hardware will print this log when the kernel boot-up.
There is no problem, please ignore it.
