I definitely didn’t blacklist F0:6E:0B:78:E2:2F. I use adguard with my lists and that’s it.
F0:6E:0B:78:E2:2F its my xbox
Thanks again! Could you describe what did you configure for this client using adguard?
Only add filters:
AdGuard DNS filter
https://adguardteam.github.io/AdGuardSDNSFilter/Filters/filter.txt
AdAway Default Blocklist
https://adaway.org/hosts.txt
1Hosts (mini)
https://adguardteam.github.io/HostlistsRegistry/assets/filter_38.txt
WindowsSpyBlocker - Hosts spy rules
https://adguardteam.github.io/HostlistsRegistry/assets/filter_23.txt
https://adguardteam.github.io/HostlistsRegistry/assets/filter_2.txt
The NoTracking blocklist
https://adguardteam.github.io/HostlistsRegistry/assets/filter_32.txt
Peter Lowe's Blocklist
https://adguardteam.github.io/HostlistsRegistry/assets/filter_3.txt
Steven Black's List
https://adguardteam.github.io/HostlistsRegistry/assets/filter_33.txt
Scam Blocklist by DurableNapkin
https://adguardteam.github.io/HostlistsRegistry/assets/filter_10.txt
Perflyst and Dandelion Sprout's Smart-TV Blocklist
https://adguardteam.github.io/HostlistsRegistry/assets/filter_7.txt
The Big List of Hacked Malware Web Sites
https://adguardteam.github.io/HostlistsRegistry/assets/filter_9.txt
NoCoin Filter List
https://adguardteam.github.io/HostlistsRegistry/assets/filter_8.txt
Phishing URL Blocklist (PhishTank and OpenPhish)
https://adguardteam.github.io/HostlistsRegistry/assets/filter_30.txt
Dandelion Sprout's Anti-Malware List
https://adguardteam.github.io/HostlistsRegistry/assets/filter_12.txt
Thank you very much! It will be fixed next version, and you can also fix it with command below:
[ -s "/etc/config/gl-black_white_list" ] && sed -i 's/option mac/list mac/g' /etc/config/gl-black_white_list
Thank you for the support.
On the last stable 4.4.5 all fine.
Try last snapshot 4.5.0 Date Compiled: 2023-10-07 20:55:04 (UTC+03:00)
SHA256: 97a59d0aa6b3c3dc1b80f8198474f893a66d3d6a35e3db4b56478d8bca0dad25
working good, see only 1 bug and again in “Clients” ![]()
Unknown error occurred. Please check the network environment or reboot the device.
But clients see.
Log https://mega.nz/file/Ecc1AZQI#PaPHcREkL1SYbIMBbBLMe9dtatARUhx4l_xCMkZee44
It will be fixed in version 4.4.6_release2.You can execute the command above and check again whether it works.Thanks!
Do you have a link on 4.4.6_release2¿
v4.4.6 release2 beta for MT2500/MT3000 are released.
https://dl.gl-inet.com/?model=mt2500&type=beta
https://dl.gl-inet.com/?model=mt3000&type=beta
Thanks!
4.4.6 r2 working good. Any bugs. Only in logs:
2023/10/09 13:53:35 [alert] 4395#0: lua_code_cache is off; this will hurt performance in /etc/nginx/conf.d/gl.conf:6
2023/10/09 16:43:59 [error] 4585#0: *604 [lua] rpc.lua:146: dlopen: Error loading shared library /usr/lib/oui-httpd/rpc/wifi.so: No such file or directory while sending to client, client: 10.0.0.207, server: , request: "POST /rpc HTTP/1.1", host: "10.0.0.1"
2023/10/09 16:45:04 [error] 4585#0: *720 [lua] rpc.lua:146: dlopen: Error loading shared library /usr/lib/oui-httpd/rpc/wifi.so: No such file or directory while sending to client, client: 10.0.0.207, server: , request: "POST /rpc HTTP/1.1", host: "10.0.0.1"
cat: can't open '/var/log/nginx/access.log': No such file or directory
Thanks for your help!We will pay attention to this error message!
Has the problem been fixed in the new beta version 4.5 for Flint?
The modification has been merged to new beta version 4.5.0
Last snapshot 4.5.0 brume - modification has been merged to?
