GL-MT3000 adminPänel v4.4.6 dont see Speed and Traffic B/s?
Hey,
i have the GL-MT3000, is work fine, but in my page admin 4.4.6, i dont see the Speed and Traffic on page Clients.
I use Chrome, no script, no plugin.
im on Wifi 6, with 3 camera , my pc and one screentouch Yolobox
in total devices 5 , but no change in my page values Speed and Traffic ? after 40 Minutes without out of page and sometime i try F5 (refesh) but nothing change.
thanks
they only work properly when you disable network acceleration. (Located unter Network > Network acceleration)
hey,
it is NOT Enable.
:frowning:
Try to clear the stats and reboot the router afterwards:
not change more.
no value change.
Could you provide a screenshot, please?
voilà.
How do you connect to the internet?
i dont use internet, only use wifi.
That’s why the calculation does not work. It will be calculated based on the traffic going through WAN.
i can’t know the traffic wifi ? input and output router .??
Nope, not by using the GL GUI.
You can try to use luci for it.
At least there is a general graph already included: Status > Realtime Graphs
For stats based on the device you have to look for another solution, that’s behind my knowledge.
ok thanks for your time and responses.
Good day
