GL-MT3000 Disable WiFi
  1. I use my GL-MT3000 for wired connection. I want to disable the WiFi at firmware level. Is it possible to disable the WiFi at firmware level.
  2. On a related note, the GL-MT3000 can be used as WiFi hot spot with devices connecting to it over WiFi. I can also connect to a WiFi router for internet access. Are these two functions done by same hardware component? What components are involved in hosting WiFi vs connecting to a WiFi?
  1. Note - I have not looked into this at all. You might be able to add a startup script to rmmod the wireless modules at the kernel level. I am not sure if that is low-enough level for your desire.
  2. Yes, you can use the 2.4ghz for wifi-wan and 5ghz for wifi clients or vice versa, or use one for both purposes.
  1. Disable wifi on Admin panel, as well as already disable wifi on firmware level.
  2. As packetmonkey said, that is right. 5GHz support repeater and wifi-ap for your wireless devices at the same time. The 2.4GHz is similarly.
I was looking for information on what kind of chip does GL-MT3000 has to connect to a wifi network. For e.g. in laptops typically there is a WiFi + BT module like Intel® Wi-Fi 7 BE200 - Google Search is used to connect to wifi network.
I was also trying to understand which hardware component is responsible for a device to become a WAP.
It's an MediaTek MT7981 integrated wi-fi chipset.
