GL-MT3000 doesn't work after update
Hey!
I have again problems with my MT3000.
After update to 4.2.3, I can not get connection to WAN anymore (DHCP doesn’t work) and can not connect to wifi in repeater mode (timeout), if I connect via LAN and static IP configuration (that works).
The Box was used as travel router, to connect to external wifi and after that connect to the home VPN.
Cheers
glineter
ok, as it seems, I must just reset everything again… puh.
