GL-MT3000 OpenVPN client cannot connect to PIA
I have successfully set up OpenVPN client with NordVPN configuration files, but when I try using Private Internet Access configuration files, it will not connect.
I have tried both TCP and UDP, both CBC and GCM, both AES-128 and AES-256 and I have tried different servers.
The same server works fine using my Windows PIA client.
Is there a way of getting the whole log file? In the GL-iNet web UI, the log file keeps refreshing and only shows the last page so I cannot copy a full log to share here.
This is a subset of the log:
Thu Jun 4 06:32:52 2026 daemon.notice netifd: Interface 'ovpnclient1' is now up
Thu Jun 4 06:32:52 2026 daemon.notice netifd: ovpnclient1 (21447): RTNETLINK answers: Permission denied
Thu Jun 4 06:32:52 2026 user.notice firewall: Reloading firewall due to ifup of ovpnclient1 (ovpnclient1)
Thu Jun 4 06:32:52 2026 daemon.notice netifd: ovpnclient1 (21447): /usr/bin/rtp2.sh: eval: line 1479: can't create /proc/dns_mark/rule10100/ifnames: nonexistent directory
Thu Jun 4 06:32:53 2026 daemon.notice netifd: ovpnclient1 (21447): udp 17 59 src=10.13.112.137 dst=224.0.0.251 sport=5353 dport=5353 packets=4 bytes=584 [UNREPLIED] src=224.0.0.251 dst=10.13.112.137 sport=5353 dport=5353 packets=0 bytes=0 mark=40960 use=1
Thu Jun 4 06:32:55 2026 daemon.notice ovpnclient1[21447]: Initialization Sequence Completed
Thu Jun 4 06:33:52 2026 daemon.notice ovpnclient1[21447]: [london441] Inactivity timeout (--ping-restart), restarting
Thu Jun 4 06:33:52 2026 daemon.notice ovpnclient1[21447]: net_addr_v4_del: 10.13.112.137 dev ovpnclient1
Thu Jun 4 06:33:52 2026 daemon.info avahi-daemon[6239]: Withdrawing address record for 10.13.112.137 on ovpnclient1.
Thu Jun 4 06:33:52 2026 daemon.info avahi-daemon[6239]: Leaving mDNS multicast group on interface ovpnclient1.IPv4 with address 10.13.112.137.
Thu Jun 4 06:33:52 2026 daemon.info avahi-daemon[6239]: Interface ovpnclient1.IPv4 no longer relevant for mDNS.
Thu Jun 4 06:33:52 2026 daemon.notice netifd: Network device 'ovpnclient1' link is down
Please confirm that the same PIA profile connects properly on Windows and that your IP address on ipinfo.io reflects the VPN.
Please double-check that you've entered the correct username and password when uploading the profile to your router.
It is working fine in my tests:
Please export the full log file logread.tar by clicking "Export Log" in the top-right corner of the page System -> Log , send it to me in forum PM.
