I need help. I am in a coworking space with many wifi options. One wifi connection was working for me but yesterday stopped working for no apparent reason. When I connect the router admin panel says connected successfully and it has an IP but no access to the internet. I have noticed when I change MAC mode it connect for a second then drops again. I am on v4.6.9…..My other issue is with the other wifi options here, when I connect the router is unable to get an IP and is stuck on getting. I have seen the other threads regarding this issue but none of the fixes worked for me. I tried messing about with MAC settings and I do not think it is related to my firmware version. I am using the router as part of a tailscale vpn and custom dns settings. Things have worked fine in other locations, I am very confused about why the wifi that did work has just stopped. I need advice on the next steps to troubleshoot this. I have attached the logs from immediately after making each connection.
cantGetIP.tar (231 KB)
hasIPnoConnection.tar (229.5 KB)
