GL-MT3000 web admin is not default
Upon successful firmware upgrade to 4.7.0, I do not get the Web Admin page (https://192.168.1.1/#/login), instead I am redirected to Luci (https://192.168.1.1/cgi-bin/luci).
how do i get Web Admin back?
I have same issue
Clear your browser cache
Did you change from op24 to mtk or mtk to op24 with the settings kept?
The difference between op24 and mtk is that mtk uses port 8080 to redirect to luci.
I wonder if certain combinations of flashing causes these issues.
I'm worried there is some kind of regression going on, because /rom/uci-defaults will not run with a kept settings environment only for first boot aka (without settings kept), so in no way the port change gets updated.
your solution is to reset it.
@bruce can i request a feature for this?, make the firmware upload check if it is such flash combination and disable checkbox for keep settings with the message that it can break the ui, that will safe guard users for issues like this, or even against a potential brick.
Thanks, factory reset and restore settings? FYI - I kept settings during upgrade and my config had https port changed to 8443.
Thanks, I will collect this request.
