I have a problem setting up my GL-MT3000 with wireguard-vpn for travel-use.
The beryl has v4.8.1 firmware installed.
To test my VPN setup, I use my handy as hotspot. As wireguard-config I’m using exactly the same config as I tested successfull with my handy.
Unfortunatly I’m not able to activate a wireguard-VPN with this config in the beryl. In the dashboard I get the message that the tunnel is executed but the VPN-activation failed.
Logging says the following:
Sun May 3 15:10:31 2026 daemon.notice netifd: Interface 'wgclient1' is setting up now
Sun May 3 15:10:32 2026 daemon.warn dnsmasq[16019]: no servers found in /tmp/resolv.conf.d/resolv.conf.wgclient1, will retry
Sun May 3 15:10:32 2026 daemon.info dnsmasq[16019]: read /tmp/hosts/dhcp.wgclient1 - 3 addresses
Sun May 3 15:10:32 2026 daemon.info dnsmasq[16017]: read /tmp/hosts/dhcp.wgclient1 - 3 addresses
Sun May 3 15:11:42 2026 daemon.info dnsmasq[17791]: read /tmp/hosts/dhcp.wgclient1 - 3 addresses
Sun May 3 15:11:42 2026 daemon.notice netifd: Interface 'wgclient1' is now down
Sun May 3 15:11:43 2026 user.notice firewall: Reloading firewall due to ifdown of wgclient1 ()
Sun May 3 15:13:40 2026 daemon.notice netifd: Interface 'wgclient1' is setting up now
Sun May 3 15:13:41 2026 daemon.warn dnsmasq[21009]: no servers found in /tmp/resolv.conf.d/resolv.conf.wgclient1, will retry
Sun May 3 15:13:41 2026 daemon.info dnsmasq[21009]: read /tmp/hosts/dhcp.wgclient1 - 3 addresses
Sun May 3 15:13:41 2026 daemon.info dnsmasq[21008]: read /tmp/hosts/dhcp.wgclient1 - 3 addresses
Sun May 3 15:14:38 2026 daemon.info dnsmasq[22666]: read /tmp/hosts/dhcp.wgclient1 - 3 addresses
Sun May 3 15:14:38 2026 daemon.notice netifd: Interface 'wgclient1' is now down
Sun May 3 15:14:38 2026 user.notice firewall: Reloading firewall due to ifdown of wgclient1 ()
Sun May 3 15:15:58 2026 daemon.notice netifd: Interface 'wgclient1' is setting up now
Sun May 3 15:15:59 2026 daemon.info dnsmasq[25555]: read /tmp/hosts/dhcp.wgclient1 - 3 addresses
Sun May 3 15:15:59 2026 daemon.warn dnsmasq[25556]: no servers found in /tmp/resolv.conf.d/resolv.conf.wgclient1, will retry
Sun May 3 15:15:59 2026 daemon.info dnsmasq[25556]: read /tmp/hosts/dhcp.wgclient1 - 3 addresses
Sun May 3 15:16:41 2026 daemon.info dnsmasq[27119]: read /tmp/hosts/dhcp.wgclient1 - 3 addresses
Sun May 3 15:16:41 2026 daemon.notice netifd: Interface 'wgclient1' is now down
Any help or idea what to do or what I did wrong?
Thanks for support in advice!
Cheers
