GL-MT3000N-v2 / lan & wan ports
there are two ethernet ports (rj45) labelled LAN and WAN.
on the physical level, are they separate?
the option to change LAN to WAN is a bit confusing.
Since they are all connected to the same board they are as separate as on a switch. So yes and no the same time, depends on the further question.
they are switch ports, not router ports, correct?
can WAN and LAN be bridged together?
For Mango router, the wan and lan are in one switch. You can bridge them
