I’ve bought a GL-MT300A to use a VPN hotspot so I can watch BBC iplayer outside the UK on my Fire TV boxes. I’m using the beta 2.20 firmware and it seems to be working fine so far. What I would like to do is for the FTV to view my media server that’s on my internal network. How do I setup either a route or a bridge to my internal network (192.168 range)
Sorry my fault, let me see if I can explain myself better:
My Fire TV box connects wirelessly to my MT300A, which in-turn is connected via copper to my home router. Using VPN the Fire TV connection is routed via tun0 and out to a UK VPN server. Currently the 300A is using its own DHCP server in the IP 192.168.8 range while the rest of my home network is on the 192.168.1 range.
What I would like to do is either have a static route to my home media server or some kind of bridge where the 300A and any device connected to it can see the 192.168.1 range and or my home media server.
Its a 300A and yes I have connected it via a port on my router to the WAN port on my 300A. Also correct my router has supplied a DHCP address to the unit
Okay, so my FritzBox is my DHCP Server my NTP Server and also creates a Cable (WAN) Connection to my ISP, the GL Inet AR300M is connected from it’s WAN Port to the Lan Port of the FritzBox.
You have the AR150 set as a router (router behind a router) and if you want to communicate from PC to PC2 you probably need to set up the AR300M as a “Dumb AP” so the PCs are on the same subnet.
The AR300M’s IP of 192.168.178.53 is for the WAN port and assigned by the DHCP of the fritzbox (most likely) as the default config for the WAN on the AR300M is to get it’s DHCP address from the “ISP” which in this case it “thinks” is your Fritzbox (down stream DHCP server)
Basically you disable the LAN DHCP, set a static address in the 192.168.178.x range for the AR300M so you can connect to it (check you Fritzbox for it’s DHCP range and choose a number outside the range) and connect the cable LAN to LAN.
The problem is that V4n1X’s PC2 is connected to a VPN server via AR300M. All the traffic in PC2 is routed to the vpn server. So it cannot be access from pc.
If you have to do this, you have to configure AR300M’s firewall so that all traffic to 192.168.178.x is not routed to the vpn. It can be done using iptables I think.
