Greetings,
I have 10 units of the GL-MT300N. We are using LucI. It has custom programming with DNSMASQ. Works very good.
However, we need to install the GL-MT300N in a metal enclosure.
Can we install an external antenna? If yes. Where are the recommended solder points?
If this can’t be done, do you have a router with the same specs and that works with OpenWRT Luci that has an external antenna connection?
Thank you, The answer here will determine and large purchase. Please send me your direct contact information for the United State.
F.Cepeda
