Hi, I purchased GL.iNet GL-MT300N-V2 on October 3rd 2019 and wanted some information.
the connection via wifi is ok, but I have difficulties when I connect the router via LAN to my Samsung smart TV (model UE55F7000SZ), to allow the connection I have to restart the router from the web every time.
Something wrong or there is an objective problem that cannot be solved, because if it were so I ask you for another model that does not present these problems to buy.
When I connect the TV to the router it tells me cable disconnected several times and still does not connect to the router.
I confirm that after restarting the router the TV is connected to the internet.
Don’t restart the router the second time
Thanks.
