Hello
GL-MT300N-V2 can’t connect to any wifi network. The problem always is the same in GUI: 'wrong key". Via logread: “wifi_join return=-5”.
Firmware tried: 3.011, 3.012, 3.022
Can anybody help me make it work?
Hello
You can upgrade firmware to 3.022 , then reset the router and try again.
I’m having the same issues with 3.022 and older firmware. My main network is not ddwrt if that makes a difference with trying to set up repeater mode.
