Hello
Sorry for my english, i’m French
I’m noob and i need help to configure , If possible, My mango GL-MT300N-V2
I’m Using DSL with some probleme (many disconnection) and i need that the GM-MT300N-V2 switch automatiquely to the USB tethering 4G modem (my phone) when the DSL cut off
It’s possible ?
Yes ?, how ? as router or as bridge ?
How
You cannot do this for your settings. When configured as lan, then it really means lan. So Mango has only one Internet connection which is your phone tethering. It will not failover.
thanks but how can i do what i want ?
Are the cabling (connexions) OK ?
if i plug the optical converter in the Wan port configue as Wan
what are the configuration ? dhcp ? Ip static but with which parameter ?
My parameter in my provider box are IP 192.168.1.1
mask 255.255.255.0 and DNS 192.168.1.1
DHCP range 192.168.1.102 to 170
I’m using range 192.168.1.2 to 101 for Ip static
