Good morning,
I’m spanish, sorry if my english is not good
I have a GL-MT300N-V2. The Led’s are always blank, both the one on the left (power) and the one on the right.
I have entered http://192.168.8.1/cgi-bin/luci/admin/system/leds, following the indications of the GL-Inet doc to change them and there is no way to do it.
Any suggestion.
Thank you.
AlquiAstri
This is the information sent by the GL.iNet support specifically for the GL-MT300N-V2 cd3 model,
"Hi
Sorry to inform you that the led color is unable to change, but you can modify the middle light.
The led lights on new device seems to be changed to white light, which are unable to change to other color.
Sorry for the inconvenience this caused you.
Regards,"
My solution:
Disassemble and paint inside the desired colors the power indicator (red) and the wifi indicator (blue). They are two transparent bastocytes.
Too easy.
Regards.
Sorry that I cannot undersand your questions and your solution.
I think our support talked with you in Spanish!
So how is the led light? Would it look like blue and red? Could you send a picture?
