GL-MT300N-V2 (Mango) Slow Internet
Currently no VPN is active.
Connected to my BT router.
BT router has both WiFi networks disabled.
Running a speed test connected to the Mango via cable or WiFi I’m getting 15-20m download from my 50-60m internet.
I’ve connected directly to my BT router and I’m not seeing the issue.
Faulty Mango or have a missed a setting?
Mango connect to your main router via cable?
If you test WAN to LAN it should not cut speed.
@alzhao
Yes I’m connected directly via Ethernet.
Is there somewhere on the device I can test this?
15-20m or 50-60m, you mean mbit/s or MByte/s
If it is the later it is totally normal. The router is 100Mbps.
If it is mbit/s, pls check below:
You can check if the link speed is at 100mbps.
On your pc you may find in network status.
On the mini router, use swconfig dev switch0 show
@alzhao
My internet is 65MBs when running test directly on my BT router im getting the full 65MBs.
When connecting the Mango directly to the BT router i get between 10-20Mbs,
speeds
Looking at the command you kindly provided i can see a few ports all running at 100baseT full-duplex.
So I’m at a loss? I don’t understand why I’m loosing so much speed via a 1 meter ethernet cable?
I’ve changed cables also.
I don’t have an idea why.
Pls use the correct unit, it is Mbps which is Mbit/s
MBps may means MByte/s which is 8 times of Mbit/s
