I am trying to get the router to connect to a OpenVPN client. I have uploaded the ovpn config and certificates, created the connection but when I click connect I don’t get any other feedback to say why it isn’t connecting. Is there anyway to get a log of the connection?
The screen shot that I am seeing is below and this is only as far as I can get with the connection.
The only logs I am getting is
Thu Mar 19 09:23:58 2020 user.info : 1326: gl-vpn-client>> Start, vpnpath=/etc/openvpn/ovpn7, serverfile=pfsense-udp-6805-AndrewCarrick-ios-config - Copy.ovpn
Thu Mar 19 09:23:58 2020 user.info : 1382: gl-vpn-client>> glconfig.openvpn.ovpn=/etc/openvpn/ovpn7/pfsense-udp-6805-AndrewCarrick-ios-config - Copy.ovpn, glconfig.openvpn.clientid=ovpn7
Removing the spaces from the config file name still has the same problem.
Thu Mar 19 10:52:22 2020 user.info : 1326: gl-vpn-client>> Start, vpnpath=/etc/openvpn/ovpn8, serverfile=pfsense-udp-6805-AndrewCarrick-ios.ovpn
Thu Mar 19 10:52:22 2020 user.info : 1382: gl-vpn-client>> glconfig.openvpn.ovpn=/etc/openvpn/ovpn8/pfsense-udp-6805-AndrewCarrick-ios.ovpn, glconfig.openvpn.clientid=ovpn8
@andrewc87 send me his ovpn privately and I found that the server IP cannot be resolved. So it may be an internal DNS or something. Waiting for more info.
Thanks for your help. I installed the OpenWrt openvpn plugin and used that with my config and the issue was that it included tls-remote which has been depreciated and it returned the error in the log where as the GL.iNet openvpn plugin didn’t report the error in the log. Once I removed this line it works perfectly now.
