I have a little problem after install the last firmware, openwrt-mt300n-v2-3.105, from scratch on my mango.
I try to start stunnel but I recive this error:
Error loading shared library libssl.so.1.0.0: No such file or directory (needed by /usr/bin/stunnel)
Error loading shared library libcrypto.so.1.0.0: No such file or directory (needed by /usr/bin/stunnel)
Error relocating /usr/bin/stunnel: OCSP_response_get1_basic: symbol not found
Error relocating /usr/bin/stunnel: X509_email_free: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_by_id: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_current_compression: symbol not found
Error relocating /usr/bin/stunnel: EC_KEY_new_by_curve_name: symbol not found
Error relocating /usr/bin/stunnel: RAND_file_name: symbol not found
Error relocating /usr/bin/stunnel: BIO_s_mem: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_get_id: symbol not found
Error relocating /usr/bin/stunnel: BIO_new_file: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_load_private_key: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_current_expansion: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_ex_data_X509_STORE_CTX_idx: symbol not found
Error relocating /usr/bin/stunnel: X509_STORE_CTX_set_error: symbol not found
Error relocating /usr/bin/stunnel: CRYPTO_set_locking_callback: symbol not found
Error relocating /usr/bin/stunnel: BIO_write: symbol not found
Error relocating /usr/bin/stunnel: OCSP_REQ_CTX_set1_req: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_use_certificate: symbol not found
Error relocating /usr/bin/stunnel: SSL_CIPHER_get_name: symbol not found
Error relocating /usr/bin/stunnel: TLSv1_2_client_method: symbol not found
Error relocating /usr/bin/stunnel: X509_STORE_CTX_get_ex_data: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_psk_server_callback: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_get_verify_mode: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_timeout: symbol not found
Error relocating /usr/bin/stunnel: X509_NAME_cmp: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_check_private_key: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_load_builtin_engines: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_servername: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_get_verify_callback: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_get_cert_store: symbol not found
Error relocating /usr/bin/stunnel: SSL_alert_desc_string_long: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_use_PrivateKey: symbol not found
Error relocating /usr/bin/stunnel: BIO_free_all: symbol not found
Error relocating /usr/bin/stunnel: SSL_SESSION_get_ex_data: symbol not found
Error relocating /usr/bin/stunnel: ERR_get_error: symbol not found
Error relocating /usr/bin/stunnel: PEM_def_callback: symbol not found
Error relocating /usr/bin/stunnel: OCSP_REQUEST_new: symbol not found
Error relocating /usr/bin/stunnel: TLSv1_server_method: symbol not found
Error relocating /usr/bin/stunnel: CRYPTO_set_dynlock_destroy_callback: symbol not found
Error relocating /usr/bin/stunnel: SSL_set_session: symbol not found
Error relocating /usr/bin/stunnel: DES_set_key_unchecked: symbol not found
Error relocating /usr/bin/stunnel: SSL_set_rfd: symbol not found
Error relocating /usr/bin/stunnel: SSL_load_error_strings: symbol not found
Error relocating /usr/bin/stunnel: X509_check_email: symbol not found
Error relocating /usr/bin/stunnel: SSLeay_version: symbol not found
Error relocating /usr/bin/stunnel: SSL_connect: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_session: symbol not found
Error relocating /usr/bin/stunnel: sk_num: symbol not found
Error relocating /usr/bin/stunnel: OCSP_request_add1_nonce: symbol not found
Error relocating /usr/bin/stunnel: CRYPTO_THREADID_set_callback: symbol not found
Error relocating /usr/bin/stunnel: X509_NAME_print_ex: symbol not found
Error relocating /usr/bin/stunnel: SSL_CONF_CTX_set_ssl_ctx: symbol not found
Error relocating /usr/bin/stunnel: OCSP_check_validity: symbol not found
Error relocating /usr/bin/stunnel: X509_free: symbol not found
Error relocating /usr/bin/stunnel: EC_KEY_free: symbol not found
Error relocating /usr/bin/stunnel: CRYPTO_set_id_callback: symbol not found
Error relocating /usr/bin/stunnel: CRYPTO_set_mem_ex_functions: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_get_first: symbol not found
Error relocating /usr/bin/stunnel: DH_size: symbol not found
Error relocating /usr/bin/stunnel: DES_set_odd_parity: symbol not found
Error relocating /usr/bin/stunnel: d2i_SSL_SESSION: symbol not found
Error relocating /usr/bin/stunnel: SSL_set_wfd: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_sess_set_get_cb: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_cipher_list: symbol not found
Error relocating /usr/bin/stunnel: SSL_set_verify: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_use_PrivateKey_file: symbol not found
Error relocating /usr/bin/stunnel: SSL_CONF_CTX_free: symbol not found
Error relocating /usr/bin/stunnel: TLSv1_1_server_method: symbol not found
Error relocating /usr/bin/stunnel: SSL_CONF_CTX_new: symbol not found
Error relocating /usr/bin/stunnel: SSL_pending: symbol not found
Error relocating /usr/bin/stunnel: X509_STORE_set_flags: symbol not found
Error relocating /usr/bin/stunnel: SSL_alert_type_string_long: symbol not found
Error relocating /usr/bin/stunnel: X509_STORE_CTX_get_error_depth: symbol not found
Error relocating /usr/bin/stunnel: SSL_load_client_CA_file: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_client_cert_engine: symbol not found
Error relocating /usr/bin/stunnel: EVP_set_pw_prompt: symbol not found
Error relocating /usr/bin/stunnel: SSL_ctrl: symbol not found
Error relocating /usr/bin/stunnel: OCSP_sendreq_nbio: symbol not found
Error relocating /usr/bin/stunnel: X509_load_crl_file: symbol not found
Error relocating /usr/bin/stunnel: TLSv1_2_server_method: symbol not found
Error relocating /usr/bin/stunnel: CRYPTO_THREADID_set_numeric: symbol not found
Error relocating /usr/bin/stunnel: OCSP_cert_status_str: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_load_verify_locations: symbol not found
Error relocating /usr/bin/stunnel: BIO_free: symbol not found
Error relocating /usr/bin/stunnel: OBJ_nid2ln: symbol not found
Error relocating /usr/bin/stunnel: BIO_ctrl: symbol not found
Error relocating /usr/bin/stunnel: BIO_new: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_peer_certificate: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_get_next: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_get_ex_new_index: symbol not found
Error relocating /usr/bin/stunnel: UI_OpenSSL: symbol not found
Error relocating /usr/bin/stunnel: SSL_set_accept_state: symbol not found
Error relocating /usr/bin/stunnel: TLSv1_client_method: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_new: symbol not found
Error relocating /usr/bin/stunnel: BIO_test_flags: symbol not found
Error relocating /usr/bin/stunnel: SSL_accept: symbol not found
Error relocating /usr/bin/stunnel: OCSP_RESPONSE_free: symbol not found
Error relocating /usr/bin/stunnel: OCSP_response_status_str: symbol not found
Error relocating /usr/bin/stunnel: SSL_CIPHER_get_bits: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_sess_set_remove_cb: symbol not found
Error relocating /usr/bin/stunnel: DH_free: symbol not found
Error relocating /usr/bin/stunnel: SSL_CONF_cmd: symbol not found
Error relocating /usr/bin/stunnel: OCSP_parse_url: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_ctrl: symbol not found
Error relocating /usr/bin/stunnel: X509_LOOKUP_hash_dir: symbol not found
Error relocating /usr/bin/stunnel: PEM_write_bio_X509: symbol not found
Error relocating /usr/bin/stunnel: SSLeay: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_register_all_complete: symbol not found
Error relocating /usr/bin/stunnel: ERR_clear_error: symbol not found
Error relocating /usr/bin/stunnel: SSL_state_string_long: symbol not found
Error relocating /usr/bin/stunnel: TLSv1_1_client_method: symbol not found
Error relocating /usr/bin/stunnel: OCSP_basic_verify: symbol not found
Error relocating /usr/bin/stunnel: OCSP_sendreq_new: symbol not found
Error relocating /usr/bin/stunnel: BIO_pop: symbol not found
Error relocating /usr/bin/stunnel: OCSP_crl_reason_str: symbol not found
Error relocating /usr/bin/stunnel: MD4_Final: symbol not found
Error relocating /usr/bin/stunnel: BIO_set_flags: symbol not found
Error relocating /usr/bin/stunnel: SSL_shutdown: symbol not found
Error relocating /usr/bin/stunnel: X509_STORE_CTX_get_error: symbol not found
Error relocating /usr/bin/stunnel: CRYPTO_set_dynlock_create_callback: symbol not found
Error relocating /usr/bin/stunnel: SSL_set_connect_state: symbol not found
Error relocating /usr/bin/stunnel: OPENSSL_add_all_algorithms_noconf: symbol not found
Error relocating /usr/bin/stunnel: BN_free: symbol not found
Error relocating /usr/bin/stunnel: SSL_version: symbol not found
Error relocating /usr/bin/stunnel: SSL_new: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_ctrl: symbol not found
Error relocating /usr/bin/stunnel: SSL_COMP_add_compression_method: symbol not found
Error relocating /usr/bin/stunnel: DH_new: symbol not found
Error relocating /usr/bin/stunnel: PEM_read_bio_DHparams: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_current_cipher: symbol not found
Error relocating /usr/bin/stunnel: X509_STORE_CTX_get_current_cert: symbol not found
Error relocating /usr/bin/stunnel: ERR_error_string_n: symbol not found
Error relocating /usr/bin/stunnel: SSL_SESSION_free: symbol not found
Error relocating /usr/bin/stunnel: X509_verify_cert_error_string: symbol not found
Error relocating /usr/bin/stunnel: SSL_COMP_get_compression_methods: symbol not found
Error relocating /usr/bin/stunnel: SSL_read: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_client_CA_list: symbol not found
Error relocating /usr/bin/stunnel: BIO_new_socket: symbol not found
Error relocating /usr/bin/stunnel: DES_ecb_encrypt: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_ex_data: symbol not found
Error relocating /usr/bin/stunnel: SSL_get1_session: symbol not found
Error relocating /usr/bin/stunnel: SSL_library_init: symbol not found
Error relocating /usr/bin/stunnel: MD4_Init: symbol not found
Error relocating /usr/bin/stunnel: SSL_SESSION_get_timeout: symbol not found
Error relocating /usr/bin/stunnel: RAND_write_file: symbol not found
Error relocating /usr/bin/stunnel: d2i_PKCS12_bio: symbol not found
Error relocating /usr/bin/stunnel: X509_LOOKUP_ctrl: symbol not found
Error relocating /usr/bin/stunnel: PKCS12_parse: symbol not found
Error relocating /usr/bin/stunnel: OCSP_resp_find_status: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_sess_set_new_cb: symbol not found
Error relocating /usr/bin/stunnel: X509_STORE_get1_certs: symbol not found
Error relocating /usr/bin/stunnel: MD4_Update: symbol not found
Error relocating /usr/bin/stunnel: OCSP_cert_to_id: symbol not found
Error relocating /usr/bin/stunnel: SSL_set_ex_data: symbol not found
Error relocating /usr/bin/stunnel: SSL_set_SSL_CTX: symbol not found
Error relocating /usr/bin/stunnel: SSL_SESSION_get_ex_new_index: symbol not found
Error relocating /usr/bin/stunnel: COMP_zlib: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_version: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_session_id_context: symbol not found
Error relocating /usr/bin/stunnel: i2d_SSL_SESSION: symbol not found
Error relocating /usr/bin/stunnel: SSL_SESSION_get_id: symbol not found
Error relocating /usr/bin/stunnel: X509_get_issuer_name: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_peer_cert_chain: symbol not found
Error relocating /usr/bin/stunnel: X509_get_subject_name: symbol not found
Error relocating /usr/bin/stunnel: SSL_set_shutdown: symbol not found
Error relocating /usr/bin/stunnel: CRYPTO_num_locks: symbol not found
Error relocating /usr/bin/stunnel: OCSP_REQ_CTX_free: symbol not found
Error relocating /usr/bin/stunnel: RAND_bytes: symbol not found
Error relocating /usr/bin/stunnel: BN_bin2bn: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_ctrl_cmd_string: symbol not found
Error relocating /usr/bin/stunnel: BIO_f_base64: symbol not found
Error relocating /usr/bin/stunnel: CRYPTO_set_dynlock_lock_callback: symbol not found
Error relocating /usr/bin/stunnel: X509_get1_ocsp: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_default_passwd_cb: symbol not found
Error relocating /usr/bin/stunnel: SSL_CONF_CTX_set_flags: symbol not found
Error relocating /usr/bin/stunnel: BIO_read: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_ctrl_cmd: symbol not found
Error relocating /usr/bin/stunnel: X509_check_ip_asc: symbol not found
Error relocating /usr/bin/stunnel: BN_num_bits: symbol not found
Error relocating /usr/bin/stunnel: X509_STORE_CTX_get_chain: symbol not found
Error relocating /usr/bin/stunnel: SSL_CIPHER_description: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_verify: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_callback_ctrl: symbol not found
Error relocating /usr/bin/stunnel: BIO_push: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_ex_new_index: symbol not found
Error relocating /usr/bin/stunnel: SSL_set_fd: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_flush_sessions: symbol not found
Error relocating /usr/bin/stunnel: OCSP_check_nonce: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_use_certificate_chain_file: symbol not found
Error relocating /usr/bin/stunnel: OCSP_response_status: symbol not found
Error relocating /usr/bin/stunnel: RAND_egd: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_init: symbol not found
Error relocating /usr/bin/stunnel: X509_STORE_add_lookup: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_SSL_CTX: symbol not found
Error relocating /usr/bin/stunnel: OCSP_request_add0_id: symbol not found
Error relocating /usr/bin/stunnel: SSLv23_server_method: symbol not found
Error relocating /usr/bin/stunnel: OCSP_BASICRESP_free: symbol not found
Error relocating /usr/bin/stunnel: SSL_free: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_psk_client_callback: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_shutdown: symbol not found
Error relocating /usr/bin/stunnel: OCSP_CERTID_free: symbol not found
Error relocating /usr/bin/stunnel: sk_value: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_ex_data: symbol not found
Error relocating /usr/bin/stunnel: ERR_remove_thread_state: symbol not found
Error relocating /usr/bin/stunnel: ERR_peek_error: symbol not found
Error relocating /usr/bin/stunnel: SSLv23_client_method: symbol not found
Error relocating /usr/bin/stunnel: DH_generate_parameters_ex: symbol not found
Error relocating /usr/bin/stunnel: SSL_CONF_CTX_finish: symbol not found
Error relocating /usr/bin/stunnel: OCSP_REQ_CTX_add1_header: symbol not found
Error relocating /usr/bin/stunnel: OPENSSL_config: symbol not found
Error relocating /usr/bin/stunnel: SSL_COMP_get_name: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_info_callback: symbol not found
Error relocating /usr/bin/stunnel: ERR_peek_last_error: symbol not found
Error relocating /usr/bin/stunnel: SSL_write: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_get_ex_data: symbol not found
Error relocating /usr/bin/stunnel: RAND_load_file: symbol not found
Error relocating /usr/bin/stunnel: SSL_SESSION_set_ex_data: symbol not found
Error relocating /usr/bin/stunnel: sk_pop: symbol not found
Error relocating /usr/bin/stunnel: X509_check_host: symbol not found
Error relocating /usr/bin/stunnel: X509_get0_pubkey_bitstr: symbol not found
Error relocating /usr/bin/stunnel: OCSP_CERTID_dup: symbol not found
Error relocating /usr/bin/stunnel: sk_pop_free: symbol not found
Error relocating /usr/bin/stunnel: OBJ_txt2nid: symbol not found
Error relocating /usr/bin/stunnel: CRYPTO_free: symbol not found
Error relocating /usr/bin/stunnel: PKCS12_free: symbol not found
Error relocating /usr/bin/stunnel: OCSP_REQUEST_free: symbol not found
Error relocating /usr/bin/stunnel: RAND_status: symbol not found
Error relocating /usr/bin/stunnel: SSL_get_error: symbol not found
Error relocating /usr/bin/stunnel: SSL_state: symbol not found
Error relocating /usr/bin/stunnel: ASN1_TIME_print: symbol not found
Error relocating /usr/bin/stunnel: X509_LOOKUP_file: symbol not found
Error relocating /usr/bin/stunnel: ENGINE_set_default_string: symbol not found
Error relocating /usr/bin/stunnel: SSL_CTX_set_client_CA_list: symbol not found
What can I do?
Thank you
