I did some OpenVPN tests to ensure it works for me when on the road. I noticed, that when I change the connection to a different server, even though it says VPN is up, the browser gives an error:
This site can’t be reached whatismyipaddress.com refused to connect. Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
Sometimes OpenVPN re-connect fixes the problem, more often it requires the router reboot to fix it.
Any thoughts on how we can prevail?
========this is what i see via webUI========
sbin/route add -net 0.0.0.0 netmask 0.0.0.0 gw 192.168.1.1
Closing TUN/TAP interface
/sbin/ifconfig tun0 0.0.0.0
/etc/openvpn/update-resolv-conf tun0 1500 1585 10.255.251.2 255.255.255.0 init
SIGTERM[soft,exit-with-notification] received, process exiting
Could not determine IPv4/IPv6 protocol
SIGHUP[soft,init_instance] received, process restarting
OpenVPN 2.4.5 mipsel-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
Restart pause, 5 second(s)
NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
RESOLVE: Cannot resolve host address: uk2.safervpn.net:1194 (Try again)
++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
VERIFY EKU OK
VERIFY OK: depth=0, C=US, ST=CA, L=SanFrancisco, O=SaferVPN, OU=SaferVPN, CN=SaferVPN, name=SaferVPN, emailAddress=support@safervpn.com
Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
[SaferVPN] Peer Connection Initiated with [AF_INET]94.177.255.67:1194
TUN/TAP device tun0 opened
TUN/TAP TX queue length set to 100
do_ifconfig, tt->did_ifconfig_ipv6_setup=0
/sbin/ifconfig tun0 10.255.251.4 netmask 255.255.255.0 mtu 1500 broadcast 10.255.251.255
/etc/openvpn/update-resolv-conf tun0 1500 1585 10.255.251.4 255.255.255.0 init
