Please check if the link ‘PC->GL-MT300N-V2->ROUTER’ and ‘ROUTER->PRINTER’ connected?
You can log in to the ROUTER background or use the third terminal connect to the ROUTER to check.
Hi,Raphael
It seems no problem with this link.
But you mean you can access the PRINTER config page from PC but can’t activate the printer?
What port use in PRINTER?
