GL-MT300NV2 lockout after IP change
This feels so stupid - i am changing the router IP address from it's initial 192.168.8.1 to 192.168.10.1, apply, await the reboot, reconnect the wifi. Wifi connection is good, the DHCP gives correct address in the new ip range. I ping the Mango - all is well. Then i try to connect via the web interface (http or https, Firefox) - can not connect. So i try to ssh into it - Connection refused, total lockout.
So i factory reset, change the ip again - same problem.
Bad Mango or shtty sysadmin? FW is 5.10.176
ssh root@192.168.10.1 fails?! Can you at least ping it? I presume you've tried hard lined/ethernet cable connection.
We tested using the MT300N-V2 with firmware version 4.3.25 and kernel version 5.10.176, but could not reproduce the problem.
It may be an IP conflict issue.
If the MT300N-V2 is still at 192.168.8.1, could you ping 192.168.10.1 successfully when ssh to router?
