GL-MT5000 Brume 3 - Upload speed from 50 mbps to 0.20 mbps (casual)
Hi all.
My configuration:
  • GL-iNet Brume 3 security gateway
  • Multiwan with policy routing
  • wan1 Vodafone FTTC (100mbps/20mbps)
  • wan2 Vodafone FWA (320mbps/50mbps)
  • Default wan: wan1
  • Some clients exits with wan2
All works without problems, until upload speed on wan2 go down to 0.10/0.20 mbps. When it happens, I must connect on Vodafone FWA router and toggle down/up 5G (upload speed back to normal).
Is there anything I can do about Brume3? Or is it just a Vodafone router issue that's going haywire for some reason (the strange thing is that download speeds are still running at 320 Mbps).
Since the download speed remains normal while only the upload speed drops, we would first like to determine whether the issue is on the Brume 3 side or the upstream Vodafone FWA side.
When the issue occurs again, before toggling 5G or rebooting either device, could you please connect a PC directly to the Vodafone FWA router via Ethernet and run another speed test?
If the upload speed is still very low when directly connected to the FWA router, we can focus on the upstream/FWA side. If it returns to normal, we can continue checking the Brume 3 configuration and WAN2 connection.
