GL-MT6000 + AdGuard
I jsut got the Flint 2 GL-MT6000. I was wondering if there is a way to only run the Adguard on the internal or Guest LAN only?
Lan and lan guest, in luci has default 2 firewalls
Thank you for your response. So when going into Luci i checked
Network > Firewall
I checked tabs
General Setting
Port Forwards
Traffic Rules
Nat Rules
Custom Rules
I dont see Adguard in there at all
is here not display the ADG rule: 53->3053 if enabled the ADG?
