GL-MT6000 and AX1800 connection isssues
I'm new to this channel, Just bought the GL-MT6000 and travel AX1800 and am trying to setup Wireguard but I not getting any advice is welcome
Fri Oct 25 23:29:24 2024 daemon.notice netifd: Interface 'wgclient' is now down
Fri Oct 25 23:29:24 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Fri Oct 25 23:29:24 2024 daemon.notice netifd: wgclient (27015): Name does not resolve: `xxxxxxx.glddns.com:51820'
Fri Oct 25 23:29:24 2024 daemon.notice netifd: wgclient (27015): Configuration parsing error
The error indicated what the issue is: Your GLDDNS name can't be resolved.
Please check if GLDDNS is active and working. See Dynamic DNS - GL.iNet Router Docs 4
If this does not work, try to disable GLDDNS and enable it again.
Appreciate your reopens. I fixed the DNS issues. Now I can lookup with no issues but now give Firewall issues
Sat Oct 26 14:19:56 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Oct 26 14:21:39 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Oct 26 14:21:40 2024 daemon.notice netifd: Interface 'wgclient' is now down
Sat Oct 26 14:21:40 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Oct 26 14:21:40 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Still no firewall issues :wink:
Please check that both routers have different subnets. By default every GL router uses 192.168.8.x (and 192.168.9.x) as subnet. This isn't allowed while using WireGuard.
Please make sure that one of the routers will use something like 192.168.10.x for LAN.
